Upgrade to fibre from ADSL
coachyard
Good Afternoon,
I have last week upgraded to fibre connection from ADSL.
I do live a long way from an exchange but i seem to be getting a very slow speed for upload and download considering its fibre.
Upload of around 0.5 M and download of around 3-4 M. I was under the impression that the download was to be between 8-14M.
Is there something that can be looked at?
Fixes: 50
Re: Upgrade to fibre from ADSL
Have you actually been upgraded OR have you just received the 'your product change is complete' email ?
If the latter then there's a pretty good chance that the actual upgrade hasn't happened yet and you're still on ADSL
coachyard
No i did question that!
My ADSL service was around 1 meg download and 0.75 up.
My service stopped working and i had to change the router on Friday morning just gone.
Browni
Aspiring Hero
Fixes: 45
Have a look here @coachyard.
That will show the speeds you can expect and also may show when your fibre will go live if there is details of an open order in the narrative.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
coachyard
There is no open order as it has been completed.
The speeds dont match what I am receiving.
Fixes: 50
In that case you probably need to go through the broadband faults process https://www.plus.net/apps/kbdfaults
coachyard
OK i will do that. Thanks.
Plusnet Staff
Plusnet Staff
I have just tested your line and I have found a phone fault on the copper line.
Your fault has now been raised with Openreach for further investigation. They have advised the estimated time for resolution is <b>Wednesday, the 14th of December 2016</b>
You can monitor this online on ticket 139932884
 Peter Birt
 Plusnet Support Team
coachyard
Hello,
The phone line has been repaired and I now get a dial tone.
The Broadband speed hasn't improved though, i cycled the power to the router but with no change.
Plusnet Staff
Plusnet Staff
Fixes: 116
Hello @coachyard
It's possible that your broadband is still banded as a result of the recent phone fault. Leave this with me, I'll run a few tests down your line tomorrow.
And I've looked into it. Testing your broadband I can see your router is in sync at a low speed. We're possibly going to need to arrange an engineer; I've updated your fault ticket with the next step.
If you let me know once you've replied I'll progress the fault.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
