Upgrade to fibre extra - speeds not met
MickGardner
I upgraded to unlimited fibre extra 48 hours ago. The download speed has increased from 35 to 55mbps (still below the 60mpbs minimum I was promised but I can live with at) which implies that my internal wiring & kit is all ok but the upload speed hasn't changed at all - it's still around the 9mbps that I was getting before, compared to the 17-18 I was promised.
5 REPLIES 5
Fixes: 356
Re: Upgrade to fibre extra - speeds not met
@MickGardner
When you say that you were promised 17-18Mbps was this in an email from Plusnet? There is no guaranteed minimum speed on upload. You can't put any credence to the 20Mbps profile as this is fixed for all fibre extra accounts at this level regardless of the line's capability. What do you get if you put your phone number in here?  https://www.broadbandchecker.btwholesale.com/#/ADSL
A thing to note is that when you were transferred to this service the DLM will have been reset to 6dB SNR. If your line will support it then this should reduce over the coming days with a corresponding increase in speed.
MickGardner
The speeds promised were in an email from Plusnet.
See attached screendump for the BT Wholsale Broadband Checker result.
Thanks for your response.
Mustrum
Fixes: 73
Despite your assumption about your wiring, it is one of the issues that is causing your low speeds.
Do you have a VDSL filtered master socket, or are you using dangley filters?
MickGardner
Dangly ones
Mustrum
Fixes: 73
If you  report a speed fault, PN will send out an Openreach bod who will install a filtered master socket and you will get the max speeds.
You can check your speeds by removing the faceplate on your master socket and plugging into the hidden test socket. However you will have to log into the router before and after, go to the advanced section and compare before and after sync and max attainable speeds.
