Upgrade from Sagemcon 2704n to hub
- Upgrade from Sagemcon 2704n to hub
24-11-2018 11:25 AM
Having just recontracted for 18mths because of taking PN TV and because of the problems with some channels breaking up I am thinking of having my master phone socket moved so I can get rid of the PLA. At the moment I have the BT white box modem and the Sagecom 2704n router. How much would upgrading to the hub cost me? I would much prefer the streamed line look of just the router in it's new place.
Re: Upgrade from Sagemcon 2704n to hub
24-11-2018 12:53 PM
With a bit of luck as you’ve recently recontracted Plusnet will give you one for the P&P charge. Whatever you do don’t buy one from Plusnet. Go onto EBay where you can get one for very little money. If you want a better looking and better performing router then get a BT Smarthub 6 from the same source.
25-11-2018 9:26 AM
Thanks Baldrick1, All sorted now and I'm a happy bunny.
26-11-2018 11:41 AM
Hi @Mayfly, I'm glad to hear that's all sorted for you and can confirm the router is on it's way out to you and should arrive within the next 3-5 working days (although usually only taking 2-3). If there's anything else you need moving forwards please do let us know.
30-01-2019 9:17 PM
I've been with PN on fibre since middle of 2015 and have just renewed my contract earlier this month. I was using an apple router which has just died so I'm now using the original 2704N. Connectivity has been patchy and speeds are erratic. I wonder if I might be able to upgrade?
31-01-2019 12:00 PM
@neilmacinnes Sorry to hear this.
I'd recommend speaking with our Customer Options team regarding this.
They can be contacted on 0800 013 2632 and are open the following hours
- Monday to Friday- 9 am while 8 pm
- Saturday - 9 am while 7 pm
- Sunday - 9 am while 6 pm
Let us know if there's anything else we can help with
