Upgrade from ADSL to Fibre
June1
Was just wondering as I won't be around until later on the day of upgrade. Do I need to unplug my ADSL router before I go out and can I plug the new one in and leave it? Any advise on this would be appreciated.
4 REPLIES 4
Re: Upgrade from ADSL to Fibre
@June1 - If you're using the Plusnet supplied router then I think this will be OK, and when you come back it should all be working. Smiley
June1
Thanks. Yes I have the hub 1. Wasn't sure which way to play it.
Fixes: 395
@June1, If you've got the Plusnet Hub one then that will work on both ADSL and Fibre so you can plug it in now and check that it works. As @Anonymous says , when your upgrade happens it should detect the change and resync to the Fibre connection.
June1
Thanks to you both for the advise
