turn on suggestions
Upgrade from ADSL to Fibre
- Upgrade from ADSL to Fibre
11-01-2016 3:29 PM
I do hope someone can clarify my query.
I am considering upgrading to fibre from Plusnet ADSL but I would prefer to keep my existing router - it has an ethernet WAN port.
What I'm struggling to understand is whether Open Reach will provide a VDSL modem as part of the install? Some posts imply they won't but the Plusnet information implies they will. Which is correct?
Thanks for your help
1 REPLY
Re: Upgrade from ADSL to Fibre
11-01-2016 5:38 PM
They stopped being automatically provided when Plusnet launched their Hub One VDSL Modem/Router. Whether they have any spare available now I can't answer that but there are many BT Openreach VDSL modems available to buy on Ebay should you not be able to get one from Plusnet or BT Openreach.
