Upgrade from ADSL to Fibre
FIXED- Subscribe to RSS Feed
- Re: Upgrade from ADSL to Fibre
05-03-2017 3:49 PM
Was just wondering as I won't be around until later on the day of upgrade. Do I need to unplug my ADSL router before I go out and can I plug the new one in and leave it? Any advise on this would be appreciated.
Fixed! Go to the fix.
05-03-2017 3:57 PM
@June1 - If you're using the Plusnet supplied router then I think this will be OK, and when you come back it should all be working.
05-03-2017 3:59 PM
Thanks. Yes I have the hub 1. Wasn't sure which way to play it.
05-03-2017 4:02 PM
@June1, If you've got the Plusnet Hub one then that will work on both ADSL and Fibre so you can plug it in now and check that it works. As @Anonymous says , when your upgrade happens it should detect the change and resync to the Fibre connection.
05-03-2017 4:05 PM
Thanks to you both for the advise
