Upgrade disappointments HELP
- Re: Upgrade disappointments HELP
19-01-2019 3:33 PM
Can't see the faceplate, but a Dect Phone, the spiders web of cables, and is that an alarm control panel? sitting so close to your router is only asking for trouble,
Without seeing your router stats, in particular the max attainable speeds, and if they change in the test socket, or which model you have, it is hard to say if a newer master socket would help
19-01-2019 3:40 PM
"One thing I have noticed though is that the estimated line length figures on the reports posted are not consistent. Not sure if that is just a gremlin."
I think its pretty close, I did a straight line on google maps, at 367.06 meters.
Estimated Line Length In Metres | 464.5 |
19-01-2019 3:44 PM
haha that's not cables, its my wicker heart ornament.
p.s the phone is discounted , as its no longer used with unlimited mobile calls now.
speed tests have been done with and without the phone attached.
and yes that just a panel for the alarm code, which is housed separately.
19-01-2019 3:48 PM
19-01-2019 3:52 PM
oh, soo much dust haha, please ignore that.
19-01-2019 3:53 PM
It is pointless doing speed tests, from what I have seen you are getting results close to your sync speed and profile.
It takes time for the profile to change, at the least overnight. Logging in to your router and showing the stats including max attainable will be far more informative.
19-01-2019 3:59 PM
19-01-2019 4:24 PM
Moderator's Note(s)
Two threads by the OP merged and unlocked.
Forum Moderator and Customer
19-01-2019 4:33 PM
@Mav Thank you.
@Pinkpanda Alas your Netgear router does not give much useful information, depending on how technical you are, or want to get, you could telnet into it and get the results of xdslctl ?
Otherwise you will need to leave the router in the test socket for a few days to see if the sync speeds improve.
19-01-2019 4:41 PM
I am not sure why, but I am struggling to enter debug mode on my d6400 to gain access telnet.
19-01-2019 4:45 PM
Try http://192.168.0.1/setup.cgi?todo=debug
Well that's what I use on my D7000.
19-01-2019 5:00 PM
really strange, prompts for password, but does show the debug screen on IE or Chrome.
19-01-2019 5:08 PM
It's a feature they introduced a while back on a firmware upgrade!
19-01-2019 5:31 PM
okay, sorted, they latest firmware has done something to the debug menu, but ive managed a work around
never used this application so not sure what i am looking at.
19-01-2019 5:33 PM
connection stats
xdslctl info --stats
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 26530 Kbps, Downstream rate = 66313 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 64861 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.5 10.0
Attn(dB): 16.4 0.0
Pwr(dBm): 13.9 7.1
VDSL2 framing
Bearer 0
MSGc: -6 20
B: 243 239
M: 1 1
T: 0 64
R: 10 0
S: 0.0000 0.3819
L: 16963 5028
😧 8 1
I: 254 120
N: 254 240
Q: 8 0
V: 0 0
RxQueue: 52 0
TxQueue: 13 0
G.INP Framing: 18 0
G.INP lookback: 13 0
RRC bits: 0 24
Bearer 1
MSGc: 154 -6
B: 0 0
M: 2 0
T: 2 0
R: 16 0
S: 6.4000 0.0000
L: 40 0
😧 3 0
I: 32 0
N: 32 0
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 1320441
OHFErr: 0 22
RS: 3058489336 1136624
RSCorr: 1699 0
RSUnCorr: 0 0
Bearer 1
OHF: 5724700 0
OHFErr: 2 0
RS: 57246381 0
RSCorr: 8 0
RSUnCorr: 1 0
Retransmit Counters
rtx_tx: 13757 0
rtx_c: 178 0
rtx_uc: 0 0
G.INP Counters
LEFTRS: 1 0
minEFTR: 64844 0
errFreeBits: 90941490 0
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 2879517710 0
Data Cells: 201221188 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 15
SES: 0 0
UAS: 30 30
AS: 91954
Bearer 0
INP: 48.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 0.00 6.13
OR: 0.01 33.91
AgR: 64927.04 20033.74
Bearer 1
INP: 4.50 0.00
INPRein: 4.50 0.00
delay: 3 0
PER: 16.06 0.01
OR: 79.68 0.01
AgR: 79.68 0.01
Bitswap: 24/24 5/5
Total time = 1 days 1 hours 33 min 4 sec
FEC: 1699 0
CRC: 0 22
ES: 0 15
SES: 0 0
UAS: 30 30
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Latest 15 minutes time = 3 min 4 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 15 minutes time = 15 min 0 sec
FEC: 36 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: N/A
Latest 1 day time = 1 hours 33 min 4 sec
FEC: 213 0
CRC: 0 6
ES: 0 6
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 1 day time = 24 hours 0 sec
FEC: 1486 0
CRC: 0 16
ES: 0 9
SES: 0 0
UAS: 30 30
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Since Link time = 1 days 1 hours 32 min 33 sec
FEC: 1699 0
CRC: 0 22
ES: 0 15
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
