Update to previous thread RE: "FTTC available but shocking speed estimate?" and GEA Test
- Update to previous thread RE: "FTTC available but ...
13-10-2018 1:57 PM
Hello, just thought I would give an update to an older thread.
In short: I could order VDSL (5-8mbps) but ADSL checker was showing slower speeds than my ADSL 2+ line (10-20mbps).
I was told my line was over 2km from the cab and I thought that was wrong.
Two weeks ago the ADSL checker updated the speed estimate so I promptly ordered.
I have now been connected for little over a week and my speeds are
I am unsure as to what could have changed as there were no vans/roadworks in the area as far as I could see. I still think this was some sort of error on the openreach system but I am very glad that it has been sorted out. I was repeatedly told that my line was over 2km to the cab by the openreach when using the contact openreach form.
My current stats
I think I have had one disconnect when the line increased in speed overnight (Current and max rate), other than that it has been rock stready.
Could I please have a GEA test on the line?
Many thanks.
Re: Update to previous thread RE: "FTTC available but shocking speed estimate?" and GEA Te
15-10-2018 9:33 AM
Hello @drunkzombie,
Thanks for getting in touch. I have run a GEA test which can be seen below;
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 63.6 Mbps |
Upstream Speed | 17.3 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 558.9 |
Upstream Rate Assessment | Reasonable |
Downstream Rate Assessment | Good |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | From 19:15 to 19:30 |
Interference Location | Customer Premise |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-10-06T08:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 54.3 Mbps | 63.6 Mbps | 61.9 Mbps |
Up Stream Line Rate | 17.3 Mbps | 17.7 Mbps | 17.4 Mbps |
Up Time | 851.0 Sec | 900.0 Sec | 899.8 Sec |
Retrains | 0.0 | 2.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-10-15T07:57:33Z | 2018-10-15T08:12:33Z |
Ingress Code Violation | 7 | 7 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
