Unstable connection.
mathewjknott
My fibre connection has become somewhat unstable.
Looking at the router logs its a lot worse than I first through.
00:50:25, 09 Feb. ( 1758.280000) PPPoE is up -​ Down Rate=56946Kbps, Up Rate=9719Kbps; SNR Margin Down=3.4dB, Up=6.1dB
00:02:54, 09 Feb. (934701.370000) PPPoE is down after 760 minutes uptime [Disconnected]
11:22:30, 08 Feb. (889077.470000) PPPoE is up -​ Down Rate=56700Kbps, Up Rate=9798Kbps; SNR Margin Down=3.1dB, Up=6.2dB
11:20:21, 08 Feb. (888947.820000) PPPoE is down after 2018 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
01:41:56, 07 Feb. (767846.650000) PPPoE is up -​ Down Rate=55796Kbps, Up Rate=9742Kbps; SNR Margin Down=3.9dB, Up=5.8dB
01:41:22, 07 Feb. (767812.890000) PPPoE is down after 484 minutes uptime [Disconnected]
17:37:01, 06 Feb. (738751.620000) PPPoE is up -​ Down Rate=55796Kbps, Up Rate=9742Kbps; SNR Margin Down=3.2dB, Up=6.2dB
17:34:50, 06 Feb. (738621.350000) PPPoE is down after 325 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
12:09:20, 06 Feb. (719091.340000) PPPoE is up -​ Down Rate=56375Kbps, Up Rate=9637Kbps; SNR Margin Down=3.1dB, Up=6.2dB
12:07:10, 06 Feb. (718960.800000) PPPoE is down after 4207 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
13:59:53, 03 Feb. (466528.720000) PPPoE is up -​ Down Rate=55749Kbps, Up Rate=10556Kbps; SNR Margin Down=3.2dB, Up=6.1dB
13:58:27, 03 Feb. (466443.060000) PPPoE is down after 3378 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
05:40:01, 01 Feb. (263741.040000) PPPoE is up -​ Down Rate=55800Kbps, Up Rate=10589Kbps; SNR Margin Down=3.2dB, Up=6.0dB
05:37:51, 01 Feb. (263611.410000) PPPoE is down after 4386 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
04:31:10, 29 Jan. ( 412.970000) PPPoE is up -​ Down Rate=55984Kbps, Up Rate=10600Kbps; SNR Margin Down=3.2dB, Up=6.0dB
04:26:45, 29 Jan. ( 148.130000) PPPoE is down after 0 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
04:26:25, 29 Jan. ( 127.810000) PPPoE is up -​ Down Rate=58860Kbps, Up Rate=13272Kbps; SNR Margin Down=1.5dB, Up=4.5dB
14:57:44, 15 Jan. <<<<<<<<<<<<<<<<<<<< Limit of wan log >>>>>>>>>>>>>>>>>>>>
What can be done to make my connection more stable?
1 REPLY
Fixes: 205
Re: Unstable connection.
Sorry to hear you're having issues.
Most of the drops in the log you've posted are between midnight and 6am which is generally when our suppliers carry out maintenance.
If the drops continue in normal hours I'd recommend raising a fault here
 Matthew Wheeler
