Unstable connection
- Re: Unstable connection
Unstable connection
01-03-2015 12:24 AM
Anyone else seen this?
I turned the power off to both my BT openreach modem and Netgear WNR1000 router (as instructed by Support). I then turned the modem back on and after about 20 min the DSL light on the BT modem went solid. I then turned my router on and at the point at which it tries to log in to the internet the dsl light on the modem goes out and the other lights start to flash. After several hours of flashing the connection came back for another few hours before I lost it again. If I disconnect the router, either by turning off the power to it or by removing the connection to the modem, the dsl light comes back solid only to go out when the connection between the modem and router is re-established.
In case it is the router that is the problem I connected the modem directly to a computer but this also made the dsl light go out. I then turned the computer off and the dsl light came back on but immediately went off again as soon as power was restored to the computer.
(Ticket no: 99989863)
Message 1 of 8
(1,030 Views)
7 REPLIES 7
01-03-2015 12:05 PM
That sounds like either a faulty modem or a dodgy Ethernet cable. Have you tried a different cable?
Message 2 of 8
(542 Views)
01-03-2015 8:16 PM
Yes, I used a different ethernet cable to connect the computer to the modem.
I have also, since I read your post, tried a different cable from the BT modem to the router.
As soon as a connection is established with the BT modem the dsl light goes out.
Message 3 of 8
(542 Views)
01-03-2015 8:30 PM
Almost certainly a faulty modem. You'll need to raise a fault.
https://faults.plus.net/
Message 4 of 8
(542 Views)
02-03-2015 11:05 AM
Message 5 of 8
(542 Views)
02-03-2015 12:54 PM
As per above, there is already a ticket no. 99989863.
I'm available whenever the engineer can call. Almost always in can ensure access if given an hour's notice.
Message 6 of 8
(542 Views)
02-03-2015 1:15 PM
Message 7 of 8
(542 Views)
05-03-2015 3:37 PM
Thanks. I decided to test if it was the modem by taking it to a friend that also has fibre. Since it didn't work on his line either it seemed it was a safe bet that you were right and it was the modem. I went out and bought an Asus DSL-AC68U modem/router and was up and running again
The engineer turned up this morning and after some tests agreed it was a fault with the modem and replaced it. So I now have a backup
Message 8 of 8
(542 Views)
