Unstable Speed
- Unstable Speed
- « Previous
- 1
- 2
- Next »
Re: Unstable Speed
14-05-2020 12:41 PM
Problem solved! Using another router (with good WiFi properties) as a bridge from the Plusnet router (which is very basic), I now get good WiFi speeds all over the house.
I did quite a bit of research into the routers and concluded that the plusnet didn't have particularly good WiFi properties whereas the router I still had from TT (also a Sagemcom) had much better WiFi coverage.
Thanks to all for your comments.
Message 16 of 18
(278 Views)
Re: Unstable Speed
14-05-2020 2:19 PM
Hi @AlanN
Glad to hear that this problem has been resolved at your end. Did you use Ethernet cable to connect both routers?
Unfortunately, I chucked my old router last week.
Message 17 of 18
(268 Views)
Re: Unstable Speed
14-05-2020 2:51 PM
Yeah, just a short cable between them-they're side by side anyway. Hope you manage to get yours sorted soon.
Alan.
Alan.
Message 18 of 18
(255 Views)
- « Previous
- 1
- 2
- Next »
