Unsatisfied Customer
- Unsatisfied Customer
Re: Unsatisfied Customer
17-05-2015 5:32 PM
adie:quote
17-05-2015 5:35 PM
The PN techies tomorrow may be able to confirm that G.INP is on your line. I really don't know what it is other than it's supposed to cope with 'cross-talk' as cabinets fill up!
You can see on the piccie in my previous post how the Billion has improved things.
York.
17-05-2015 5:43 PM
Quote from: NedLudd It's possible!
Thanks again and thanks to everyone else. Sorry I came down too hard on people and Plusnet. What do you think to this ZyXEL VMG8924-B10A its also TR-069 remote management
The ZyXEL VMG8924-B10A incorporates the TR-069 standard management specifications for service providers to manage and configure client devices remotely without any end user intervention. This feature offers a true “plug-and-play” experience while reducing deployment complexity to help saving the operating and maintenance costs for service providers.
17-05-2015 6:04 PM
If you really want to wade into technicalities, please see the G.INP thread on this board. There are some technical disagreements there, but what I've just stated is not one of those.
17-05-2015 6:08 PM
17-05-2015 6:23 PM
Quote from: Anotherone Let's be clear, the G.INP issue does NOT affect all lines and all modems. The problem cases are usually where you have a Huawei Cabinet and a ECI modem. This affects SYNC speed, not throughput speed directly. If you are still getting your usual max. speed at non-peak times, then your issue has nothing to do with G.INP.
Let's also be clear that my modem is locked down and I cannot get any line stats so I don't know if the problem is G.INP only plusnet can tell me if its enabled on my line or until I replace my modem.
17-05-2015 6:25 PM
17-05-2015 6:58 PM
Please run the BTw Performance test (DON'T REBOOT, ignore the red preamble except make sure no other programs are using the Internet and you are using an ethernet link) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
Do a Copy and Paste of the results and post here (no need to grab an image).
17-05-2015 7:33 PM
adie:quote
17-05-2015 7:38 PM
Whenever it's convenient, no rush.
17-05-2015 7:43 PM
adie:quote
17-05-2015 7:48 PM
17-05-2015 7:50 PM
I then installed a new 8800NL Billion router and noticed no difference at all in speed
On the plus side I can now see that my line is going as fast as it reasonably can with a download SNR of 6dB (Info that wasn't available with the PN / BTOR setup)
17-05-2015 7:55 PM
Well it may have changed and that's what G.INP should have done, adversely so if you were affected by that issue, so it's best to see a new result.
When you are referring to Plusnet changing your "sync" speed, that is something they cannot do, an Openreach engineer has to go to the Cab to reset things and that's something they won't do readily on Fibre except when there's been some sort of fault. It's not like ADSL/ADSL2+ where the ISP can do a remote reset I'm afraid.
I suspect what they changed was your Current Line speed (Login required). That's Plusnet reflection of BT's IP Profile and should match it (rounded down to the nearest 200kbps) to ensure you get good Traffic management. Unfortunately the data for that has to be sent from BT's servers to Plusnet's servers and that doesn't always happen when it should.
17-05-2015 8:00 PM
adie:quote
