Unlimited Fibre speed has dropped to 12.95 Mbs
What download speed should I expect from Unlimited Fibre in SS& 5TE?
My speed was quite acceptable until last week when it dropped to 12.95 Mbs.
Can a PlusNet technician look into this please.
Regards
Gary
12 REPLIES 12
Re: Unlimited Fibre speed has dropped to 12.95 Mbs
Oops!  SS7 5TE
I should get upto 76 Mbps with U/L Fibre
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (Mbps): 15.60
Upload Speed (Mbps) : 2.83
Ping Latency (ms): 15
Fixes: 124
Hi Gary,
76mbps is the maxium the fibre service can offer, the speeds within that depend on your line. You should have had an email from us from around the time of upgrading to fibre with speed estimates. You can find those out again though by entering your details at https://www.dslchecker.bt.com/
I've tested your line and results reflect the speeds you've mentioned but don't show an obvious cause for the issue so can you give the checks shown here a try next please? https://goo.gl/Rnae7N
Do let us know how you get on.
 Adam Walker
Hi Adam,
All checks pass OK.  I have rebooted the PC and router several times over the past few days.  Not only is the connection noticeably slower, but accessing websites and performing TLS handshakes takes quite a few seconds (upto 15 secs each time).  Therwith the DSL results.  Which product refers to me?
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 58.8 40 14.3 8.8 35 Available Available --
VDSL Range B (Impacted) 56.7 35 14.1 8 28.8 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 8 -- 5.5 to 12.5 Available -- --
WBC ADSL 2+ Annex M Up to 8 Up to 1 5.5 to 12.5 Available -- --
ADSL Max Up to 5.5 -- 4.5 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps) 19.99
Max Upstream Observed Speed (Mbps) 6.87
Observed Date 2019-03-27
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 21-03-2019
The router is fixed to the following DNS.  How can I change it to a faster DNS?  Is the DNS fixed to PlusNet so our usage can be minitored?
Regards
Gary
Primary DNS: 212.159.6.10
Secondary DNS: 212.159.6.9
Fixes: 124
Thanks Gary, it's the VDSL speeds (i.e the top two) that relate to your line.
The best thing to do next would be to raise a fault with us at http://faults.plus.net can you drop us a reply back here when you have please?
 Adam Walker
Hi Adam,
I tried to report the fault, but the fault line has a fault!
Error
Sorry, we are not able to complete this request at the moment, please try again later.
Fixes: 124
Not to worry, it's opened a ticket on your account so I've been able to raise the fault to our suppliers. We'll update you as soon as we can.
 Adam Walker
Champion
Fixes: 22
212.159.6.10
212.159.6.9
If you're using a residential router, then this can't be changed on the router, but you can change it on your device - google if you're not sure Wink
If your router is a business router, then it can be changed on the router.
Hi Adam,
Please can you make thye status of this problem - Urgent.
My Internet connection is virtually unusable.  It can take a minute just to do a TLS handshake!
Regards
Gary
Thanks DS.  I have now changed my IPv4 DNS settings.
Champion
Fixes: 22
Glad to hear it Gary Wink
(I do find Quad 9's to be pretty good 9.9.9.9 - though I have reverted to PN allocated DNS for some testing)
Fixes: 55
Hi @GaryWilliams,
I'm really sorry to hear that you're experiencing these issues with your speeds. I've updated the fault ticket on your account regarding this issue, which can be viewed here.
Please let us know once you get the chance to read and respond to the ticket so that we can pick this back up for further review as soon as possible.
 Alex H
