Unlimited Fibre line speed = 19.2Mbps??
Snug
Can anyone tell me why this might be? is my connection limited for some reason?
I'm on a newly installed line when I moved into this address. DLM period should be over. I've tried with my plusnet homehub and my ASUS router. Both give me the same results.
I've changed filters, cables, connected with ethernet, turned off wifi, master socket faceplate off, etc.
no matter what I get a maximum 2Mbps up and 20Mbps down?
Your broadband service
  • Product: Unlimited Fibre
  • Estimated Download Range: 38 - 40Mbps
  • Estimated Upload Range: 8 - 10Mbps
  • Minimum Guaranteed Speed: 30.9Mbps
  • Current Line Speed (Download): 19.2Mbps???
any help is appriciated.
4 REPLIES 4
adam945
Fixes: 105
Re: Unlimited Fibre line speed = 19.2Mbps??
Thanks a lot for reaching out, and I'm sorry to hear about the issues you've outlined above.
I've sent you an email stating what's been done on the account if you'd like to take a look.
-Adam
 Adam
 Plusnet Help Team - Leeds
Snug
Thank you for looking into this. I can see the change in the max data rate in my DSL settings but has my broadband username and password been changed? They’re no longer being accepted by either router.
adam945
Fixes: 105
Hi there, thanks for reaching out again.
No change has been made to the router settings. I can see that there has been a stable connection for the past four hours. Please feel free to let me know if you're having any further issues.
-Adam
 Adam
Snug
Hello. after several disconnections the last week a support ticket was raised and a fault was found on the line.
The connection dropped again at about midday today and has not reconnected since.
