Unlimited Fibre faults/lag
billylong1
I'm on the 40MB Unlimited Fibre package and have been getting nothing but trouble the last week or two.
This started happening before I changed to the Hub One, swapped out the TG582 for that hoping for better but it appears to be in PlusNet/BT's domain rather than being a local issue, changed to a TP-Link TL-WR940N which has sped up internal traffic but done nothing for the lag issues.
I waited to see if it was something that would just pass but it hasn't and is really frustrating now.
My speed tests run at 36Mbps Down and 1.6Mbps Up, on my wired connection (PS4) and wireless (PC, Android, et al), all with the same problems.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Unlimited Fibre faults/lag
Can you describe the actual issues you've having a little more?
Is it any game, specific games? Lobby, or once you're in the same? Anything using the connection at the same time?
 Chris Parr
 Plusnet Staff
billylong1
Hi Chris, of course.
It's any game, any online streaming application whether it be Rocket League, NHL16, Neflix, or WWE Network on PS4 or Rocket League, CS:GO, Netflix, WWE Network or NFL Network on PC.
With games it's usually in-game and online lobby, offline of course is okay.
With streaming services (Netflix et al), it's streaming and menus (loading times for menus). Even when throttling the streaming service speed to under 400Kbps it's laggy and requires buffering.
The only concurrent connections would be two Android phones at the same time running nothing in particular, average social use, no videos being played on them or anything. I disconnected everything else but the PS4 and PC (both which were on at different times) and still had the issues.
Plusnet Staff
Plusnet Staff
Fixes: 159
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 2.0 Mbps
Can you provide a tracert to a couple of affected sites, such as netflix.com and maybe a gaming site? Testing your line isn't showing any issues at all.
 Chris Parr
 Plusnet Staff
billylong1
Netflix
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\me>tracert www.netflix.com
Tracing route to www.eu-west-1.prodaa.netflix.com [54.217.208.149]
over a maximum of 30 hops:
1 8 ms 1 ms 2 ms 192.168.0.1
2 * * * Request timed out.
3 * * * Request timed out.
4 12 ms 22 ms 14 ms be3-3106.psb-ir02.plus.net [195.166.143.140]
5 12 ms 12 ms 18 ms 195.99.125.142
6 20 ms 17 ms 17 ms peer6-hu0-11-0-1.telehouse.ukcore.bt.net [195.99
.127.13]
7 12 ms 14 ms 16 ms 109.159.253.83
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 23 ms 54 ms 23 ms 178.236.0.134
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 23 ms 36 ms 37 ms ec2-79-125-0-247.eu-west-1.compute.amazonaws.com
[79.125.0.247]
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
WWE Network
C:\Users\me>tracert network.wwe.com
Tracing route to a1128.g2.akamai.net [95.101.128.194]
1 6 ms 3 ms 2 ms 192.168.0.1
3 13 ms 13 ms 12 ms 141.hiper04.sheff.dial.plus.net.uk [195.166.143.
141]
4 12 ms 16 ms 11 ms be3-3106.psb-ir02.plus.net [195.166.143.140]
5 12 ms 11 ms 12 ms 195.99.125.138
6 14 ms 13 ms 30 ms peer1-et-10-1-0.telehouse.ukcore.bt.net [195.99.
127.3]
7 13 ms 31 ms 14 ms peer2-xe8-0-2.telehouse.ukcore.bt.net [195.99.12
6.157]
8 15 ms 13 ms 12 ms a95-101-128-194.deploy.akamaitechnologies.com [9
5.101.128.194]
Trace complete.
CS:GO game server
C:\Users\me>tracert 193.33.177.33
Tracing route to rev.193.33.177.33.pukawka.pl [193.33.177.33]
1 2 ms 1 ms 1 ms 192.168.0.1
4 12 ms 15 ms 13 ms be3-3104.psb-ir01.plus.net [195.166.143.136]
5 12 ms 12 ms 12 ms core1-BE1.southbank.ukcore.bt.net [195.99.125.13
0]
6 15 ms 12 ms 13 ms vhsaccess1-pos2-0.faraday.fixed.bt.net [195.99.1
27.5]
7 13 ms 12 ms 12 ms t2c4-et-8-3-0-0.uk-lon1.eu.bt.net [166.49.211.25
0]
8 12 ms 14 ms 13 ms hu0-1-0-0.ccr22.lon01.atlas.cogentco.com [130.11
7.14.229]
9 * 14 ms 14 ms be2870.ccr41.lon13.atlas.cogentco.com [154.54.58
.173]
10 22 ms 23 ms 20 ms be12194.ccr41.ams03.atlas.cogentco.com [154.54.5
6.94]
11 33 ms 32 ms 31 ms be2815.ccr41.ham01.atlas.cogentco.com [154.54.38
.206]
12 45 ms 45 ms 45 ms be2252.ccr21.waw01.atlas.cogentco.com [154.54.60
.254]
13 * 45 ms 45 ms be2407.rcr11.b036814-0.waw01.atlas.cogentco.com
[154.54.37.58]
14 * 45 ms 45 ms etop.demarc.cogento.com [149.6.71.90]
15 48 ms 44 ms 44 ms 80.72.33.10
16 45 ms 46 ms 44 ms rev.193.33.177.33.pukawka.pl [193.33.177.33]
Trace complete.
