Unlimited Fibre extra speed below estimate.
DigitalSoul
I have upgraded to the Unlimited Fibre Extra package a couple of weeks ago but only receiving around 38mbps. The estimates were around 68 - 78mbps. I spoke to the plusnet customer service about this a week ago but I've heard nothing since and it seems the ticket has been closed with no resolution.
I've attached line speed, DSL checker etc.
Thanks.
6 REPLIES 6
Fixes: 1,483
Re: Unlimited Fibre extra speed below estimate.
Looking at the speedtest the upgrade may not have gone through as your upload speed is still at the 10Mbps too.
Need a PN staff member to have a look.
DigitalSoul
Just to clarify that the upgrade was from standard broadband. I've just received an email in regard the closed ticket, stating that extended test have shown the line has settled down.
Still no change in speed though. Is it possible to have been put on the wrong package?
Mustrum
Fixes: 77
If you post the info on the Helpdesk tab of your router, making sure you obscure your username and any other sensitive information, then we should be able to give you more info.
It could be your internal wiring that is slowing your speeds, do you have a filtered master socket fitted?
DigitalSoul
Yeah there's a filtered master socket fitted, I've tried plugging into the test socket too. I don't have access to the router at the moment but I'll post the info as soon as I can.
DigitalSoul
Here are the details from the Helpdesk tab:
1. Product name: Plusnet Hub
2. Serial number: [Removed]
3. Firmware version: Software version 4.7.5.1.83.8.237.2.2 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 00:26:23
6. Data rate: 11546 / 41535
7. Maximum data rate: 11546 / 42044
8. Noise margin: 6.2 / 4.8
9. Line attenuation: 25.9 / 19.0
10. Signal attenuation: 25.9 / 17.7
11. Data sent/received: 307.0 MB / 8.5 GB
12. Broadband username: XXXXX@plusdsl.net
13. 2.4 GHz Wireless network/SSID: [Removed]
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: [Removed]
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 3c:17:10:82:87:64
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
Moderator's note by Mike (Mav): Post released from Spam Filter.
Moderator's note by Mike (Mav): Personal information removed from a public forum.
Fixes: 1,600
Hi there.
I'm sorry to hear you're experiencing speed problems.
The think the next step is to book an engineer visit to further investigate.
I'll update your ticket shortly on your account.
