Unlimited Fibre but old ADSL speeds?
mallah
I upgraded to Unlimited Fibre a couple of days ago and set up my router yesterday without any probs, even managed to do some advanced bits to rename the WiFi and passwords so they were the same as before.
However just been checking line speeds with various online checkers and they all say my speeds are the same as they were on ADSL?  i.e. 6.92 Mbps download, 0.86 Mbps upload. What's going on?
yfront
Re: Unlimited Fibre but old ADSL speeds?
What would you expect to get using.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Fred
Moderator's note by Mike (Mav): Post released from Spam Filter
mallah
That says it should be 40Mbps. I suspect Openreach haven't done their bit despite PN sending me the go for it email?
liane14
More than likely your profile hasn't been updated correctly to account for the change. Happened to me recently but they were quick to resolve.
Browni
Seasoned Champion
Fixes: 36
On the BT checker is there any mention of an open order?
I must have been really bad in a previous life. This is my 3rd ISP in a row that uses lithium.
mallah
No mention of an open order on the checker?
Fixes: 13
@mallah
I can see you called in recently, we're taking a look at your account now hopefully can give you an update in the next 30 minutes or so.
Really sorry but it looks like there are no orders placed here, it looks like there are some problems as some systems suggest fibre is available and some that it is not, we've placed a ticket into our provisioning team to investigate and we will monitor it and let you know exactly what's going on.
Sorry for the inconvenience.
 Jono H
mallah
OK thanks, I'll check back tomorrow.
Fixes: 13
@mallah It's unlikely to be fixed tomorrow, I'll aim to get an update by Monday
 Jono H
mallah
Thanks, I'll keep an eye out for progress on Monday.
Fixes: 168
I've now got an order placed for you and requested the activation as soon as possible. Once we receive confirmation of the activation date from our suppliers we'll let you know.
Thanks for your patience.
 Harry Beesley
mallah
Thanks, that order was scheduled to be complete yesterday? Still got speeds as attached.
Fixes: 168
Could you try disconnecting and reconnecting and let me know if you're still experiencing speed issues now please.
 Harry Beesley
mallah
Thanks, that appears to have improved things as attached - not quite reached the promised 40mbps min but I'll keep trying at different times.
Fixes: 168
The service is capped at a maximum of 40Mbps (Advertised at up to 38Mbps) on Unlimited Fibre, however if you're testing over wireless 33Mbps might just be because the speeds would be lower over wireless compared to a wired connection.
 Harry Beesley
