Unlimited Fibre Plus upgrade - slow speed
Snufflewort
I was upgraded to fibre on Monday, but speeds didn't increase above 18Mbps, so I chatted with a Plus Net adviser who reset something and it improved to 45mbps. Now it is down to 27Mbps, and an IP profile of 77Mbps. Something isn't quite right. Can you take a look please?
7 REPLIES 7
SpendLessTime
Fixes: 86
Re: Unlimited Fibre Plus upgrade - slow speed
The thing they altered is the Plusnet line Speed which you can find here https://portal.plus.net/my.html?action=data_transfer_speed ( Login required) I would bookmark this link as Plusnet removed it from the Member Centre last year and it is handy to have to check against.
If that has been changed back down, then give them a call/Chat and get it changed again to the correct value. Once set correctly, then you will need to log onto the router, click "Disconnect", wait a minute and then click "Connect" to get the new speed values.
Snufflewort
Thanks. I just had a look and it is showing
Estimated line speed:80Mb (This may vary between 73.7Mb and 80Mb)
Current line speed:77.4 Mb
Chris
Legend
Fixes: 169
Can you try a single disconnect/reconnect and then try a wired speedtest to see what it's looking like now.
Snufflewort
Done that.
Results Image not loaded
1. Best Effort Test: -provides background information.
  Download Speed
  27.73 Mbps
0 Mbps 77.43 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 27.73 Mbps
 For your connection, the acceptable range of speedsis 61.95 Mbps-77.43 Mbps .
 Additional Information:
 IP Profile for your line is - 77.43 Mbps
  Upload Speed
  15.83 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 15.83Mbps
Terranova667
Fixes: 5
Was the test done via Wi-Fi or Ethernet cable ?,
the BTW IP profile is as it should be and the plusnet profile matches so that isn't slowing you down.
If your using Wi-Fi have you tried manually setting the channel 1,6 or 11 are the best ones to use, the problem with Wi-Fi is it's prone to interference from many things which can lower the speed especially the further away from the router you are and if brick walls ect are involved.
Snufflewort
The speed test was executed on my PC connected via Ethernet plugged direct to the Home Hub
Snufflewort
Still no better! Can I downgrade and save £10 a month for the sake of a few extra Mbps
