Unlimited Fibre Extra seems stuck on ~40 down ~2 up
froodulous
I upgraded to unlimited fibre extra, but I still seem to be getting speeds for unlimited fibre. I don't know if there is something up with my account, or if the line just cannot support the higher speeds. When I upgraded, it said the line should support it.
Gel
Seasoned Pro
Fixes: 14
Re: Unlimited Fibre Extra seems stuck on ~40 down ~2 up
froodulous
Oh bother. Sorry about that. Is there a way to move it or should I just create a new question there?
Fixes: 144
Moderator's note:
Topic moved from 'Broadband' to 'Fibre Broadband'.
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
Fixes: 210
Sorry to hear this.
It looks like the modify order wasn't placed so I've done this manually for you.
You should see faster speeds from tomorrow
 Matthew Wheeler
froodulous
Just ran a speed test an I am now getting ~45 down and ~13 up, so it looks like this has worked. Thanks a lot.
Fixes: 210
Glad to hear it's improved!
Let us know if you have any further issues
 Matthew Wheeler
