Unlimited Fibre Extra not performing to my given product speed....
Andy2020
Got Unlimited Fibre Extra from Plusnet
  • Product: Unlimited Fibre Extra
  • Estimated Download Range: 44 - 64Mbps
  • Estimated Upload Range: 8 - 10Mbps
  • Minimum Guaranteed Speed: 40Mbps
  • Current Line Speed (Download): 58.8Mbps
But only getting around 18Mbs download speeds which is nothing like above.
Anything I can do to get my broadband up to speed
Thanks.
28 REPLIES 28
Beyhive
Fixes: 44
Re: Unlimited Fibre Extra not performing to my given product speed....
Hi @Andy2020, sorry to hear you're having connection issues.
Checking from this side everything is looking spot on to the router and with no signs of errors. The speeds are syncing at 64.2Mbps download and 17.2Mbps upload. Are you connected on a wired or wireless connection?
 Faris
Andy2020
Hi there,Thanks for your quick reply,
This is the speed just now 13.21Mbps on Monday plugged into my phone socket with my laptop and a wired cable.
The speed changes through out the day when you do a speed test it jumps up to say 50Mbps and then falls down to the lower speed during the test.
Thanks.
adamwalker
Fixes: 221
Thanks for trying that Andy, it would be best to try following the checks here next: https://www.plus.net/help/broadband/connection-troubleshooting/ if the issues continue you can report a fault over at http://faults.plus.net
Please let us know how you get on.
 Adam Walker
Andy2020
Hi there, Ok will do recommended tests etc, and will work from there. Thanks.
Beyhive
Fixes: 44
No worries @Andy2020,
Let us know how it goes please.
 Faris
Andy2020
Got a email today to go and teat speed at http://www.speedtest.btwholesale.com/ the link/site does not work.
So can not do a speedtest using the btwholesale site to post it back here.
Still only getting around 21mbps when it should be very much higher
Regards.
Andy2020
Not much happening here with this slow broadband........
Andy2020
Hi there, Any help in getting this speed probleme fixed. Thanks.
MatthewWheeler
Fixes: 479
Thanks for getting back to us @Andy2020
Apologies for the delayed response.
I've just picked the fault up for you and update it with the next steps.
If you can let us know once you've responded we'll get that picked up for you
 Matthew Wheeler
Andy2020
Thanks for  your reply.
Tere are three people in my house hold and we do not understand your emails that have been sent.
There is nowhere to put a reply when we click on the given link only a button to close this request.
Don't want to press that do we.
Thanks.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Thanks for coming back to us. There has been an update on the ticket. Please log into the portal and go here. From that link, you should be able to reply and we'll move to the next steps.
 Tony T
Andy2020
Still the same slow speed at my house.
So fault is still on my line.
The BT website may say I am getting fantastic speeds down my line but it's not coming into my house.
It appears that BT cannot fix this fault and it is easier to say it's fixed and close the request than it is to repair it.
matphoto
I'm the same, on ultimate fibre, been pants for the last few weeks. I am at the point where I will be looking for another supplier, its been that bad.
I tried a BT Wholesale speed test but it seems to be having problems again.
Mads
Fixes: 79
Hey @Andy2020
I'm currently discussing this with our suppliers now and will provide an update shortly.
Thanks.
