Unlimited Fibre Extra not performing to my given product speed....
- Re: New Fibre order
- « Previous
- 1
- 2
- Next »
Re: Unlimited Fibre Extra not performing to my given product speed....
11-02-2020 2:56 PM
Further to my update, I've now updated the ongoing faults ticket for you here.
We'll provide further updates once we have them,
Thanks.
Slow fibre speed then go to www.testmy.net
22-02-2020 9:14 AM
After moving to PN in Dec last year to take full use of my Fibre Broadband I find it is slower than the provider I left.
At PN I took the below package:
Product: Unlimited Fibre Extra
Estimated Download Range: 44 - 64Mbps
Estimated Upload Range: 8 - 10Mbps
Minimum Guaranteed Speed: 40Mbps
Current Line Speed (Download): 78Mbps
Since Sunday 12th January I have had a ticket open for slow speed and have slow speed.
I have done every thing asked at my end like plug laptop into BT outlet directly using a cable etc.. Had 2 BT engineers call at house to try and fix it but still the same.
I use www.testmy.net over weeks and it shows around 24MB/ps all the time.
PN keep saying that "this matter is resolved" and are closing the ticket but I am stuck with a slow Fibre Broadband connection.
So what now....
Re: Slow fibre speed then go to www.testmy.net
22-02-2020 11:06 AM
Moderators Note
Two topics in same subject merged from same OP
22-02-2020 11:16 AM
So!!! why not, I am paying for somthing I am not getting. I would like it sorted but all PN want to do is close the ticket because they think its fixed.
Re: Speed has dropped
22-02-2020 2:07 PM
It only reaches 26Mbps or less and does not reach the speeds you may think it does.
My eyes are starting to bleed with this
22-02-2020 2:14 PM
This is my speed just now..
26-02-2020 11:54 AM
Sorry to see the issues with this are ongoing.
I've just had a read through the history of the issue and I just want to check if you've been able to tests speeds over a wired connection?
There was no specific mention of this so I just need to check that's been done.
Re: DSL down - Plusnet want to do home visit.
03-03-2020 8:12 PM
Can I have an engineer sent to my address to fix my problem of super slow fibre broadband from pn...
03-03-2020 9:58 PM
Moderators Note
Post split and moved from another thread to keep OPs posts on an issue in one place.
05-03-2020 8:25 PM
05-03-2020 8:26 PM
Can I have two engineers sent to my address to fix my problem of super slow fibre broadband from pn..
Re: New Fibre order
05-03-2020 8:28 PM
Re: New Fibre order
05-03-2020 9:19 PM
Moderators Note
Posts moved from other threads to keep comments in one place
Re: New Fibre order
11-03-2020 11:20 AM
Hi @Andy2020,
I'm very sorry that you're still experiencing problems with your connection and for the delay in getting back to you on here. Having checked on your fault, I can see that when the line was last tested an external fault was found. This has been raised to our suppliers for further investigation and our faults team will contact you once we've received an update on this. It may be the case that they'll need to arrange an engineer visit at this stage.
- « Previous
- 1
- 2
- Next »
