Unlimited Fibre Extra Speed
Embattle
I was wondering if it is normal for the current line speed to be 78mb but only get 65mb in assorted speed tests?
Plusnet Staff
Plusnet Staff
Fixes: 115
Re: Unlimited Fibre Extra Speed
Hello @Embattle A warm welcome to the community forums first of all
The current line speed on your Member Centre (known as the connection profile on our side) should automatically adjust to your sync rate every few days. If your speed is within your estimates then that's nothing to worry about.
If you would like me to run a few tests down your line, please feel free to private message with your Username.
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
Embattle
Thanks I'll message you the username just to check if possible.
Plusnet Staff
Plusnet Staff
Fixes: 115
No problems.
Thank you for your PM @Embattle
The below test results indicate you're getting a pretty high sync rate of 70.5 Mbps and there's essentially no fault detected.
xDSL Status Summary
Circuit Sync Status
: In Sync
Downstream Line Rate
: 70.5
Upstream Line Rate
: 20.0
GEA Details
Bridge Tap
: Not Detected
Radio Frequency Ingress
: Not Detected
Repetitive Electrical Impulse Noise
: Not Detected
Copper Line Test Result
: Pass
NTE Power Status
: PowerOn
Crosstalk
: Not Detected
Your speed estimate indicates a speed of between 60.1 Mbps and 79.1 Mbps which your sync speed is falling towards the top end.
Just for the sake of clarity on the Member Centre, I've manually updated the connection profile to 70000 kbps.
I hope this helps.
 Plusnet Support
Embattle
Thanks for checking.
I thought the messy phone box might be a problem but I guess it passed that test in terms of Copper line test.
Plusnet Staff
Plusnet Staff
Fixes: 115
No problems. Smiley
Anything else I can help with, please feel free to let me know.
 Plusnet Support
