Unhappy with speeds! Constant drop of connection
waqa786
Can a plus net staff reply im only getting 16mb down from 50mb im getting constant drop of Internet dsl connection just recently joined plusnet from talktalk please reply.
Fixes: 165
Re: Unhappy with speeds! Constant drop of connection
Looking at your estimates I'd expect you to be connecting at between 35.5 and 50.7Mb/s.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 50.7 35.5 11.8 7.5 34.2 Available -- -- -- --
When we test your line we can see you are connected through at 46.9Mb/s, so within that range.
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 46.9 Mbps
Upstream Speed 19.1 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 644.7
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 21:15 to 22:15
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Profile Name 0.128M-80M Downstream, Interleaving High - 0.128M-20M Upstream, Interleaving On
Time Stamp 2017-01-17T14:30:00
Are the speedtests you're seeing over a wired or wireless connection?
 Chris Parr
 Plusnet Staff
waqa786
Its wired tested using laptop and pc
waqa786
Its funny though as upload is fine which readings im getting are 21+ but download are stuck at 15mb-16 wireless or wired
waqa786
Any update on this please
Fixes: 165
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
 Chris Parr
 Plusnet Staff
waqa786
ive just turned my router of for 30min and back on and can see difference in speed from  16mb to 45mb Smiley but when browsing or downloading the connection drops I've removed the router and have inserted an openreach modem with the router and still getting slow browsing and drop connection when downloading a file . here are screenshots form bt speed test also i have included pictures from the router sync/errors hope this helps
the router i have is a tplink vr600
waqa786
Any update on this please as im still having problems
