Unhappy with speeds! Constant drop of connection
- Re: Unhappy with speeds! Constant drop of connecti...
30-01-2017 1:49 PM
Re: Unhappy with speeds! Constant drop of connection
30-01-2017 2:27 PM
Looking at your estimates I'd expect you to be connecting at between 35.5 and 50.7Mb/s.
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 50.7 | 35.5 | 11.8 | 7.5 | 34.2 | Available | -- | -- | -- | -- |
When we test your line we can see you are connected through at 46.9Mb/s, so within that range.
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 46.9 Mbps | ||||
Upstream Speed | 19.1 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 644.7 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From 21:15 to 22:15 | ||||
Interference Location | Customer Premise | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Profile Name | 0.128M-80M Downstream, Interleaving High - 0.128M-20M Upstream, Interleaving On | ||||
Time Stamp | 2017-01-17T14:30:00 |
Are the speedtests you're seeing over a wired or wireless connection?
30-01-2017 2:53 PM
31-01-2017 11:40 AM
31-01-2017 1:27 PM
31-01-2017 1:40 PM
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
01-02-2017 12:05 AM - edited 01-02-2017 12:10 AM
ive just turned my router of for 30min and back on and can see difference in speed from 16mb to 45mb but when browsing or downloading the connection drops I've removed the router and have inserted an openreach modem with the router and still getting slow browsing and drop connection when downloading a file . here are screenshots form bt speed test also i have included pictures from the router sync/errors hope this helps
the router i have is a tplink vr600
01-02-2017 3:43 PM
