Under 40Mb
Terranova667
Under 40Mb
It seems the D-side issue that Openreach didn't want to fix has now dropped me under 40Mb on a 80Mb service I have raised a ticket 132735492 and waiting for support to get back to me, this time I'm not going to let Openreach get away with doing nothing.
BTW test below
Download speed achieved during the test was - 37.07 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-38.75 Mbps .
 Additional Information:
 IP Profile for your line is - 38.75 Mbps
Fixes: 136
Re: Under 40Mb
It seems that our tests have found a fault which has automatically been raised.
 Matthew Wheeler
Terranova667
Re: Under 40Mb
Thanks for the reply Matthew good to know,  will see what comes next.
Terranova667
Re: Under 40Mb
I awoke this morning and the speed is back up to around where it normally is, not sure if Openreach did something at the cab in the early hours or something.
Any way can someone from the Plusnet Help team adjust my Plusnet Profile as it's below where it needs to be, online chat is not available at present to get it changed. thanks
Fixes: 136
Re: Under 40Mb
There's nothing that's been done that I can see.
Regardless I've updated the profile so if you disconnect then reconnect your speeds should increase.
 Matthew Wheeler
Terranova667
Re: Under 40Mb
Thanks for that Matthew all good now, hmm maybe DLM just had a fit and then fixed itself lol.
Fixes: 136
Re: Under 40Mb
Potentially although you never know with DLM.
Let us know if it happens again.
 Matthew Wheeler
