Unbearable slows speed past 3 days from 4pm onwards.
lxkid
The past 3 days my internet has been struggling , I'm used to streaming a hd movie at the same time the rest of my family are also using the Internet with no problem at all.
Now none of us can hardly do anything.
Can someone check my line? See if there's any drops etc
Plusnet Staff
Plusnet Staff
Fixes: 115
Re: Unbearable slows speed past 3 days from 4pm onwards.
Just testing your broadband,
Sync Status In Sync
Downstream Speed 75.3 Mbps
Upstream Speed 20.0 Mbps
Voice Line Test Result Pass
And, your connection from your exchange to your router is also pretty stable.
You using wireless or wired connections?
I've joined the Plusnet Help Team as of May 2017. As such, I have a new forum account. Please direct any queries to @Gandalf. Thanks
 Plusnet Support
lxkid
Wireless connections for most of the devices in our house hold, I did plug Ethernet cable in laptop to test speeds there was nothing wrong there.
So I spend most of the afternoon changing the wireless channels , it would work for a little while then it would go back to the same drop speeds as I mentioned.
As a 6 year old customer would a free hubone be available to me?
Fixes: 114
If you call us on 0800 013 2632 I'm sure we can get something arranged.
 Matthew Wheeler
