Unbearable slows speed past 3 days from 4pm onwards.
- Unbearable slows speed past 3 days from 4pm onward...
14-01-2017 6:04 PM
The past 3 days my internet has been struggling , I'm used to streaming a hd movie at the same time the rest of my family are also using the Internet with no problem at all.
Now none of us can hardly do anything.
Can someone check my line? See if there's any drops etc
Message 1 of 4
(644 Views)
3 REPLIES 3
Re: Unbearable slows speed past 3 days from 4pm onwards.
15-01-2017 8:00 AM
Just testing your broadband,
Sync Status | In Sync |
Downstream Speed | 75.3 Mbps |
Upstream Speed | 20.0 Mbps |
Voice Line Test Result | Pass |
And, your connection from your exchange to your router is also pretty stable.
You using wireless or wired connections?
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 2 of 4
(595 Views)
16-01-2017 11:02 AM
Wireless connections for most of the devices in our house hold, I did plug Ethernet cable in laptop to test speeds there was nothing wrong there.
So I spend most of the afternoon changing the wireless channels , it would work for a little while then it would go back to the same drop speeds as I mentioned.
As a 6 year old customer would a free hubone be available to me?
Message 3 of 4
(538 Views)
16-01-2017 11:51 AM
