Unable to connect to work server
- Re: Unable to connect to work server
04-07-2018 7:53 PM
I've been working from home for around 2 years and suddenly can't log into the work server. The techs from work used remote access to check for problems and could find nothing. They concluded that the problem must be with Plusnet somehow blocking the port. To check if this might be true I used wi fi in a local cafe and could log onto the work server fine. Plusnet deny any problem as they "don't support port forwarding." If this doesn't get resolved soon I might have to change service provider, as the only way to continue working from home Any ideas?
05-07-2018 9:20 AM
Hi @Mezzer
I can see @adamwalker has replied to you other thread regarding this here.
Thanks for getting in touch.
Alisdair
05-07-2018 9:24 AM
Moderator's note:
Topic locked in favour of the one in Alisdair's link above.
