Unable to connect my samsung Smart TV to new fibre router (Wirelessly)
- Re: Unable to connect my samsung Smart TV to new f...
25-11-2014 6:45 PM
Does anyone have any suggestions on how to resolve this and get it back connecting via a wireless connection?
Re: Unable to connect my samsung Smart TV to new fibre router (Wirelessly)
25-11-2014 7:19 PM
25-11-2014 7:22 PM
Yes. It finds the router no problem. I then enter my key exactly as it shows. It seraches for a min then comes up saying connection failed.
25-11-2014 8:07 PM
1 - removing security in the router (just short term as a test)
2 - Check the security type (WEP/WPA) matches what you had previously.
3 - that works, try re-enabling and using a simpler key
25-11-2014 9:05 PM
25-11-2014 9:05 PM
Are you able to give me some further details on each of the points?
25-11-2014 9:08 PM
Currently in Germany with limited web access.
Hopefully someone else can help in the short term
26-11-2014 12:17 AM
26-11-2014 8:30 AM
The Model is UE50ES6300
26-11-2014 10:36 AM
26-11-2014 10:41 AM
Sorry we couldn't be of more help on this, unfortunately there are so many devices out there we have to draw the line with supporting them somewhere. Good to hear you got it working and removing the device from the router was a good idea.
26-11-2014 12:19 PM
Quote from: nedster What I did was go into the router settings and delete the MAC address for the TV.
That could be a useful step for anyone having connection issues with virtually any device, maybe one for support to all to their standard list since it's a router setting rather than a device setting.
@Chris, see above...
Quote from: Chris unfortunately there are so many devices out there we have to draw the line with supporting them somewhere.
26-11-2014 3:16 PM
