Unable to browse URL
creeve42
Hello,
A straightforward question, can you browse www.broadbandcloudsolutions.co.uk ok? Currently it's not working at all, and i've tried 2 PCs. Other websites are fine, and I can also access this through mymobile 4G ok. Curious at to whether it works ok for others? Thanks Chris
10 REPLIES 10
billnotben
Re: Unable to browse URL
Works ok for me.
Browsers pale moon 27.2 and my pc's original IE 8
Shep41
Seasoned Pro
Fixes: 6
Works fine here for me...
mac51
No problems for me.
picbits
Works for me.
What happens if you try and ping it ? Does it resolve to [52.56.179.200] ?
What does a tracert bring up and have you checked your own IP address against blacklists to see if you are being blocked for some reason ?
creeve42
A ping does resolve to 52.56.179.200
Here's the tracert:
Tracing route to broadbandcloudsolutions.co.uk [52.56.179.200]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.100.1
2 8 ms 10 ms 10 ms 84.93.253.112
3 9 ms 9 ms 9 ms 84.93.253.119
4 9 ms 9 ms 9 ms 195.99.125.138
5 30 ms 20 ms 15 ms 194.72.16.100
6 9 ms 9 ms 9 ms 109.159.253.221
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 15 ms 12 ms 11 ms 52.94.35.37
13 11 ms 11 ms 11 ms 52.94.35.52
14 * * * Request timed out.
15 12 ms 11 ms 13 ms 52.94.34.23
16 * * * Request timed out.
17 62 ms 52 ms 29 ms 52.94.33.185
18 77 ms 11 ms 11 ms 52.94.33.48
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
TheMightyAJ
Fixes: 126
Hi @creeve42,
I'm sorry to hear that you're experiencing this issue. Have you been able to try power cycling your router? If not, I would suggest doing this, however I would also suggest leaving the router off for roughly 70 minutes before turning it back on so that you are assigned a new IP Address upon powering the device back up.
 Alex H
creeve42
Just a quick followup... my IP address was incorrectly blacklisted on SpamHaus. I've fixed that, and now it works ok. Thanks for the pointers to help me investigate.
DavidS24
it works for me too.
creeve42
Just an update to say that my IP was blacklisted in one place, and this was causing the issue. I've now resolved the issue. Thanks for your help.
DavidS24
I thought that this site has some errors, so I tried to do a technical audit and understand what the reasons could have affected this problem. For that, I used this tool https://sitechecker.pro/ for an audit and results are good in general. It has just some errors from seo optimization like: meta description, H1 tags.
