Unable to access admin area of router
Shutty666
Hi all.
I am currently unable to even get to the landing page of my router on my PC. I can access it from my mobile and a laptop but not from my desktop. All i get is the waiting for 192.168.1.254 to respond. Any clues as to what is going on?
Thanks in advance
9 REPLIES 9
dnpark38
Re: Unable to access admin area of router
Sounds most odd.
Really I've no idea but I have two things I go to on the internet and found not all browsers are compatible with them so it is clutching at straws can you try another browser?
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
Shutty666
Yep weird isn't it. I've tried chrome and firefox. Really don't want to go and try internet explorer or edge (shudder).....
Mustrum
Fixes: 77
Are you connected to the router? If so how? Tried rebooting the PC and or router? Which router is it?
ian007jen
Make sure the desktop is connected to the router via ethernet....no powerline adapters...(spawn of the devil)
Shutty666
Desktop is connected directly to the router (Technicolour TG582n) via an ethernet cable. I've already tried resetting them both to no avail. Any other suggestions?
BrightonRock1
Never come across this sort of problem.
How about trying the cable from your desktop into a different socket on the router? Or trying by cable from your laptop? Or a different cable from the desktop?
cedlor
You cant connect to the landing page but can you connect to the internet?
From a command prompt run ipconfig /all  and see what comes up as the default gateway.
notmyname
You mention that you are able to connect to the router from other devices?  Could you try logging into the router using a mobile browser and disabling "Web browsing interception"
From the left,  Technicolor gateway --- Configuration.  Then the top right corner hit "configure".
Shutty666
OK thanks for the suggestions guys.
The default gateway is set to 192.168.1.254 as I believe it should be.
I have also tried changing the Web Browsing Interruption to disabled too. Still no joy.
Any other thoughts?
