Typical UL Speed should be..??
- Re: Typical UL Speed should be..??
18-10-2014 12:33 AM
Greetings
As a simple rule of thumb what should I be experiencing as a typical (ball park) UL speed using PlusNet Unlimited Fibre?
Just thought I'd check before I launched into a moan 🙂
M
M
Message 1 of 6
(1,652 Views)
5 REPLIES 5
18-10-2014 10:14 AM
depends entirely on your line.
what does https://www.btwholesale.com/includes/adsl/main.html say ?
Message 2 of 6
(1,165 Views)
19-10-2014 1:13 AM
Maintenance in progress
btwholesale.com is temporarily unavailable while we carry out planned maintenance.
Just about sums it up really...!
I'll try later.
I'll try later.
Message 3 of 6
(1,165 Views)
19-10-2014 1:37 PM
OK, I got a result this time, can you advise which of these codes relates to the service that PlusNet are providing?
(Apologies if I'm being a bit dim here)
FTTC Range A (Clean) 27.4 19.5 5.9 3.9 -- Available
FTTC Range B (Impacted) 21.8 11.3 5 2 -- Available
WBC ADSL 2+ Up to 6 -- 4 to 8 Available
WBC ADSL 2+ Annex M Up to 6 Up to 1 4 to 8 Available
ADSL Max Up to 5 -- 3.5 to 7.5 Available
WBC Fixed Rate 2 -- -- Available
Other Offerings
FTTP on Demand 330 30 -- Available
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
Other Offerings
Message 4 of 6
(1,165 Views)
19-10-2014 2:38 PM
Hi there
The codes for FTTC don't relate to different services but more to the estimated quality of the line. For example FTTC Range A (Clean) is what we would expect you to get after a engineer install and the line has no physical faults.
FTTC Range B (Impacted) applies more towards self install and the potential of any other factors that could impact the line e.g. Bridge taps, aluminium wiring and so on.
I can see your current upload speeds are around the 4mbps mark which is within the range for your line.
Are you seeing any particular issues with your upload speeds?
Message 5 of 6
(1,165 Views)
20-10-2014 12:06 PM
Thank you for the reply which is appreciated.
Based on the figures, and your explanation of same, no I'm not experiencing any issue with my UL speed, it is performing as expected.
The issue is clearly with my expectations, I'm used to working on a line that has a typical upload speed in the 20-30mb range, trying to work from home now clearly still isn't the utopia that Raymond Baxter promised me it would be all those years ago. I haven't got my robot butler yet either, so he has more than just slow internet to answer for!
I'll check back in 10 years and see if things have improved.
Again though, thank you for the explanation.
Message 6 of 6
(1,165 Views)
