Two weeks still not repaired
lyndsaym96
Had this issue for 2 weeks. Amber bar and red broadband icon on hub 1. Numerous phone calls. New router. Open reach visit and spoke to provisions and still not resolved. Can someone from plus net have a look at our case and see if they can resolve.
No upstream or downstream. Fibre circuit isn't sending a data stream says or engineering. Looks like there was an open order on the line. Was told take 24 hrs to remove and still no connection. Phone back told another 48 hrs. It's well over that now. Looks like no resolve in sight. Please help
8 REPLIES 8
MatthewWheeler
Fixes: 479
Re: Two weeks still not repaired
Sorry to hear that.
If you can PM me your username I'll get this chased up for you.
 Matthew Wheeler
lyndsaym96
Thanks it's [Removed]
Moderator's note by Adie (Dvorak) removed users personal info as it's an open forum
MatthewWheeler
Fixes: 479
Thanks.
I'm getting this chased up for you.
 Matthew Wheeler
lyndsaym96
Thanks very much
lyndsaym96
Any update Mathew
MatthewWheeler
Fixes: 479
Thanks for your patience.
The stuck order on your line should be closed off in the next 48 hours.
Our faults team will keep a eye on it to make sure.
 Matthew Wheeler
lyndsaym96
That's sounds great and all but we got told this order take 48hrs to close for Fri it's now Tue so not buying it. I mean does anyone actually know when we will get service restored it is looking more likely I 've quicker signing up to virgin or sky this is too much. Thanks anyway Mathew
MatthewWheeler
Fixes: 479
I understand it's frustrating however at the moment we can't advise any further.
 Matthew Wheeler
