Two weeks after upgrade to fibre, still on old speed
- Re: Two weeks after upgrade to fibre, still on old...
20-11-2015 4:25 PM
Two weeks after upgrade to fibre, I'm still on the old speed.
Estimated line speed:
40Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-10-23 22:48:55
Current line speed:
6.9 Mb
I have a call logged through the member centre (#113116333) but no one is responding. Is it OK to try to get some help through the forums?
..Mike
Current line speed:
6.9 Mb
..Mike
Message 1 of 6
(1,124 Views)
5 REPLIES 5
Re: Two weeks after upgrade to fibre, still on old speed
20-11-2015 4:28 PM
Indeed you can but while you are waiting can you report the IP profile from http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do (ignore the speed test result as that is garbage)
Message 2 of 6
(606 Views)
20-11-2015 4:32 PM
Message 3 of 6
(606 Views)
20-11-2015 5:01 PM
Brilliant - fixed! [Though when I tried to post this reply I lost the internet and the router internet status was 'disconnected'. Repeated attempts clicking on Connect flashed up an unreadable message. Eventually it succeeded. I hope this is a one-off!]
Current line speed:
37 Mb
All I need now is to see whether my switch from BT phone to a PlusNet phone package materializes. (ordered at the same time as the broadband upgrade) ...
Many thanks. In future I'll post issues to the forum!
..mike
Current line speed:
37 Mb
..mike
Message 4 of 6
(606 Views)
20-11-2015 5:04 PM
Message 5 of 6
(606 Views)
20-11-2015 5:06 PM
Thank you.
Message 6 of 6
(606 Views)
