Two laptops one keeps dropping from router
- Two laptops one keeps dropping from router
- « Previous
- 1
- 2
- Next »
Re: Two laptops one keeps dropping from router
14-04-2015 12:40 PM
Quote from: npr Try configuring a different wifi channel in the router.
Channels to try are 1, 6 and 11, stick with whichever gives the best result.
I have tried every one, but it made no difference
Message 16 of 17
(210 Views)
14-04-2015 3:11 PM
Seeing as how the Win 7 lappie works ok, the probem sounds like its with the Vista laptop.
Might be worth checking that Power saving mode is disabled on the Wirless adaptor http://louisville.edu/it/departments/communications/wireless/disable-power-savings-mode-for-the-wire...
Message 17 of 17
(210 Views)
- « Previous
- 1
- 2
- Next »
