Two fold - ‘can’t connect to WiFi’ & new router
- Two fold - ‘can’t connect to WiFi’ & new router
a month ago
Recently changed from Sky to Plusnet all the devices previously connected no issues?
If I buy a better quality router would this solve it? Any suggestions for replacement router?
Thanks in advance.
Re: Two fold - ‘can’t connect to WiFi’ & new router
a month ago
Try changing channel in router settings and possibly switching 5GHz off or 2.4GHz until connected depending which frequency the item you are trying to connect functions.
a month ago
Do you have standard Broadband, that comes with a small Sagecom 2704 router (label on bottom) - if so there's a known limitation of 16 wifi devices: could this be your issue?
If it is, then you need to raise a call on plusnet and ask them for one of the better Plusnet Hub 1 routers: or buy your own / add a another WiFi access point
a month ago
Thanks for replying!
a month ago
How would I go that from a phone and printer?
Thank you
a month ago
If you’ve got fibre broadband I suspect you’ll have a Hub One. Of the 3 routers shown here https://www.plus.net/help/broadband/router-setup-guides/ which one does yours look like?
a month ago
Any suggestions as to best one to buy pls
a month ago
It’s probably worth trying the steps here https://community.plus.net/t5/My-Router/Devices-stop-working-on-5-GHz-connection-Wifi-drops/m-p/1395... first
a month ago - last edited a month ago
<deleted>
