Turn my interleave off
- Re: Turn my interleave off
25-11-2014 12:16 AM
25-11-2014 10:22 AM
Looking at that graph I'd also suggest you go through the faults checker at https://faults.plus.net as something isn't right there.
25-11-2014 11:50 AM
25-11-2014 11:55 AM
25-11-2014 12:58 PM
....as I thought that ISP's have no control over the interleaving status on the FTTC service and that it is all automatically determined by BT's DLM system which is the ultimate decider of what the line setting should be.
25-11-2014 1:02 PM
25-11-2014 4:51 PM
Quote from: Chris We don't have control over the DLM, to remove interleaving is a bit of a pain as we have to place a modify order to make any changes to interleaving.
Interesting. Unlike ADSL, there is no specific 'Interleave' option in a modify order.
Not knowing the parameters hidden away under "DLM" for an FTTC modify order. Why does that actually do? Is it a full reset of the DLM, or just (temporary) removal of interleaving?
25-11-2014 4:53 PM
Let me double check, I may be remembering it wrong but I thought there was an option for auto, on or off for interleaving. If not, then I'm sorry wilma1964, we'll have to allow DLM to do it's job, but it's a much better idea to allow the line to be connected consistently.
25-11-2014 4:58 PM
There's some discussion of this here: http://community.plus.net/forum/index.php/topic,132641.msg1158780.html#msg1158780
25-11-2014 8:50 PM
Thats a shame as I bet some people were getting excited that there may be a way to do it.
26-11-2014 9:31 AM
26-11-2014 12:15 PM
26-11-2014 12:32 PM
Even if DLM has been turned off, that doesn't suddenly mean we have new tools to remove interleaving etc.
26-11-2014 12:53 PM
For more details on goldenfibre's comment (I thought DLM was turned off by BT as of 21/11/14?) see http://www.thinkbroadband.com/news/6726-assia-court-case-forces-openreach-to-turn-off-dlm.html
What I would like is a capability to increase target SNR and stability at the cost of a lowered sync speed. I guess I could get that with a more advanced modem, but not (as far as I know) on an HG612, even unlocked. I'm on PlusNet 40/20 with SNR of 5.1 and a wasted sync speed very close to 80.
26-11-2014 1:01 PM
