Trying to post in a thread but can't see a post message button
deanol
Hello,
I am new to this forum to this may be user error!
I am trying to send a message to @bobpullen in the "Plusnet fibre broadband does not cope with uploads..." thread to request that he applies to config changes to my router as I have the same intermittent drop out symptoms and the same Hub One router (Software version 4.7.5.1.83.8.226 | Last updated 17/09/16).
Unfortunately there doesn't appear to be a "post new message" type button. I can see a "reply" to a message button but not one to add a new message.
I can send him a private message either because when I try it says I have insufficient privileges to do so. So I'm not sure what the issue is. I only registered with the forum this morning specifically to ask Mr Pullen if he can apply the changes to my router.
I tried going via the PlusNet Support Team and held a Web Chat to ask if they could contact Mr Pullen to request this but they said they could not due to Chinese walls between the forum and them. That seems silly to me, especially as they are all branded and owned by PlusNet. Mere bureaucratic nonsense.
But if someone could advise on how to post in that thread or PM Mr Pullen I would be grateful.
Thank you.
Fixes: 28
Re: Trying to post in a thread but can't see a post message button
Click on his name and this will take you to his profile, and from there you'll be able to send him a PM (right side of page)
deanol
Unfortunately that doesn't work.
All I see are options to make him a friend or ignore him. Nothing to PM him except a "Private Message" button at the bottom of the page. Clicking it tells me I have insufficient privileges.
I am not sure whether my account is set up correctly or whether I have to wait a certain length of time or post a number of messages before I can PM.
Fixes: 50
Can you try again now you have made 2 posts.
Customer and Forum Moderator.
Fixes: 29
You should now be able to PM him now that you have posted on here. If you still cant it will be because you have not verified your email address.
deanol
Thank you. It looks like posting a few messages has sorted the PM issue out.
I've also figured out how to post a new message. I have to select the "reply" button that appears in someone else's message. I assumed this would quote my message in someone else's message but it doesn't. It just posts a new message. Which I find strange UI design.
Hey Ho.
Browni
Seasoned Champion
Fixes: 36
Welcome to the Lithium forum platform Grin
I must have been really bad in a previous life. This is my 3rd ISP in a row that uses lithium.
