Trying to Order but confuse HELP
rookey
Ok Folks
I am with Plus net on ADSL... Ive had a email from Openreach and even checked their website and our exchange is now Fibre enabled so I rush off to my account to upgrade and I can't.  And plus net site even saids I can't get Fibre even though It is enabled and accepting orders looking at Openreach website...
What do we do please?
Fixes: 311
Re: Trying to Order but confuse HELP
Your exchange might be enabled, but your cabinet not enabled.
You need to enter your phone number into the wholesale checker for the definitive answer.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
rookey
It all enabled as says accepting ordet
Does it say which cabinet you're on? it should do if available  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Fixes: 158
Are you checking here http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
Customer and Forum Moderator. Windows 10 Firefox 63.0 (64-bit)
Fixes: 219
Hi there
Unfortunately your so close to your exchange that it looks like your on a exchange only line.
You won't be able to get fibre as your line won't be connected to a cabinet.
Sorry for the bad news.
 Matthew Wheeler
