Trying to Order but confuse HELP
- Re: Trying to Order but confuse HELP
20-12-2014 7:04 PM
Ok Folks
I am with Plus net on ADSL... Ive had a email from Openreach and even checked their website and our exchange is now Fibre enabled so I rush off to my account to upgrade and I can't. And plus net site even saids I can't get Fibre even though It is enabled and accepting orders looking at Openreach website...
What do we do please?
Message 1 of 6
(954 Views)
5 REPLIES 5
20-12-2014 7:27 PM
Your exchange might be enabled, but your cabinet not enabled.
You need to enter your phone number into the wholesale checker for the definitive answer.
Message 2 of 6
(594 Views)
20-12-2014 8:08 PM
It all enabled as says accepting ordet
Message 3 of 6
(594 Views)
20-12-2014 8:32 PM
Does it say which cabinet you're on? it should do if available
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 4 of 6
(594 Views)
20-12-2014 8:35 PM
Are you checking here http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
Message 5 of 6
(594 Views)
22-12-2014 12:45 PM
Hi there
Unfortunately your so close to your exchange that it looks like your on a exchange only line.
You won't be able to get fibre as your line won't be connected to a cabinet.
Sorry for the bad news.
Message 6 of 6
(594 Views)
