Trouble connecting to wifi and staying connected
FIXED- Subscribe to RSS Feed
- Trouble connecting to wifi and staying connected
03-06-2021 1:03 PM
Fixed! Go to the fix.
Re: Trouble connecting to wifi and staying connected
03-06-2021 3:54 PM
If your router has 2 band capability, ensure the 2.4 & 5ghz frequencies are given different names in your router settings.
2/
D/load a free wifi analyser app to check which channels most in use in your locale; then manually set your router wifi to the least used channels /or unused ones.
03-06-2021 4:01 PM
Hi @sarney211, thanks for getting in touch and welcome to our Community Forum.
I'm sorry to hear you've been having connection issues as of recent and checking from this side I can see we haven't seen a drop in connection between our side and the router in the last 7 days. This then points towards the router and the connection type wireless to be behind the issues you've been seeing and I'd advise first of all to run through my guide below on how best to optimise the wireless settings to best suit your property and surrounding area.
The guide below will show you how to log into the router and change the wireless channel as it's usually another router in the area on the same or similar channel that will be causing issues for both wireless frequencies. Before picking a channel I'd suggest downloading a free app called wifi analyzer (blue and white icon on android)which will scan your area for all the routers and show what channels they are on between 1-13. Although the above app isn't essential it helps you pick where your router would be best in terms of channels and saves a lot of time doing it via trial and error.
1) To connect to your Hub One, you will need to open a browser and go to 192.168.1.254 If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Advanced Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Wireless' followed by '5 GHz Wireless'. What we want to do to begin with is turn 'Sync with 2.4 GHz Wireless' to 'Off' and update the SSID to be different. The easiest way would be to add '-5G' to the end so it is identified as its own connection. Once this is changed, we will need to keep an eye on it for a day or 2 to see if the issue continues. If it does, the next step would be to change the wireless channel. Keeping in mind the original 2.4Ghz unchanged name network connection would be the best to connect your devices to for a stronger signal.
(When deciding which device goes on what frequency keep in mind that the 5GHz is designed for close range stationary devices and standard 2.4GHz the one which gets the wireless around your property further.)
4) Following the above guide to get to your 'Advanced Settings' page, you will need to change the settings within the 2.4 GHz Wireless tab and the 5 GHz Wireless tab.
5) Under the correct heading, you will need to find 'Channel Selection' on the list and change this from 'Automatic' to any one of the other channels, This can also need doing under '5 GHz Wireless' to cover both signals. Give it 3-4 hours of testing to see if the issue still persists and try to change the channel again if you see little or no improvement.
Let us know how it goes as there are other steps we can advise should this not help with the disconnections you're seeing. If your son having the most issues in the far room is a fellow gamer like myself then I'd perhaps consider looking into power line adaptors as these devices allow you to use the electrical wiring of the property to transfer a much faster and stable wired connection to opposite sides of the house from the router. Unlike wireless which when optimised can see performance issues (especially with gaming which unlike steaming or browsing can't really buffer or load ahead) the power line adaptors should make a great difference to the ping.
I hope this helps and I look forwards to hearing from you further.
03-06-2021 8:36 PM
03-06-2021 10:24 PM
04-06-2021 9:37 AM
