Translation Please
FIXED- Subscribe to RSS Feed
- Translation Please
18-11-2016 1:06 PM
After a no-show by an engineer to investigate my "fibre at dsl
speed" issue, I'm now at "BOT - FTTC Logged Faults - Post SFI".
Can anyone de-abbreviate that and/or explain it for me?
Thanks, John.
Fixed! Go to the fix.
Re: Translation Please
18-11-2016 1:26 PM
Hi @Sanctified,
Really sorry to hear the engineer hasn't arrived.
SFI mean special faults investigation, which is a bit of a glorified term that our suppliers use for an engineer appointment. Your case is in a ticket pool/workflow for our faults team for if issues are still persisting following an appointment (granted, they didn't show).
I couldn't find your account through the typical means, but I can get your fault chased up if you PM your username over.
Matty
18-11-2016 2:53 PM
Thanks for sending your username over.
I've passed the case onto my colleague who is going to give you a call once we have a sense of what happened. For my colleagues, the ticket number is 137970827.
Matty
21-11-2016 9:24 AM
Hi Matty.
Engineer arrived 8am, found that the line profile had been manually capped,
in error, because of the telephone cable break a few weeks ago.
Now back to 27Mbps, so thanks for your help in resolving this.
John.
21-11-2016 6:13 PM
Moderator's note by Dick (Strat) Solution moved to @MattyC as the provider of the solution.
