Translation Please
Translation Please
After a no-show by an engineer to investigate my "fibre at dsl
speed" issue, I'm now at "BOT - FTTC Logged Faults - Post SFI".
Can anyone de-abbreviate that and/or explain it for me?
Thanks, John.
4 REPLIES 4
Champion
Fixes: 46
Re: Translation Please
Hi @Sanctified,
Really sorry to hear the engineer hasn't arrived.
SFI mean special faults investigation, which is a bit of a glorified term that our suppliers use for an engineer appointment. Your case is in a ticket pool/workflow for our faults team for if issues are still persisting following an appointment (granted, they didn't show).
I couldn't find your account through the typical means, but I can get your fault chased up if you PM your username over.
Matty
Champion
Fixes: 46
Thanks for sending your username over.
I've passed the case onto my colleague who is going to give you a call once we have a sense of what happened. For my colleagues, the ticket number is 137970827.
Matty
Hi Matty.
Engineer arrived 8am, found that the line profile had been manually capped,
in error, because of the telephone cable break a few weeks ago.
Now back to 27Mbps, so thanks for your help in resolving this.
John.
Fixes: 481
Moderator's note by Dick (Strat) Solution moved to @MattyC as the provider of the solution.
Customer and Forum Moderator. Windows 10 Firefox 83.0 (64-bit)
