Tp link ac3200
- Tp link ac3200
Tp link ac3200
19-04-2016 2:19 PM
Hello
There was a post like this a while ago but there was no solution posted so ....
Bought a new tp link ac3200 router and tried to get it set up. Says everything is connecting but ive no access to the internet.... When i do try to access something it just goes to the BT wholesale page saying that i cant access the internet. Called tp-link and they didn't come up with anything and plusnet don't support the AC3200.
The status page on the router says I'm connected to the net but I can't access anything. Also a bit weird but .. When I put in username&plusdsl.net in it doesn't even pretend to connect but if the @ is changed for an & then it says it's connected but again no access. Any ideas?
Cheers
Davie
Cheers
Davie
Message 1 of 2
(507 Views)
1 REPLY 1
Re: Tp link ac3200
19-04-2016 2:35 PM
Message 2 of 2
(497 Views)
