Timeout establishing PPP again (fault 97715196); reoccurrence from yesterday :(
- Timeout establishing PPP again (fault 97715196); r...
- « Previous
- 1
- 2
- Next »
Re: Timeout establishing PPP again (fault 97715196); reoccurrence from yesterday :(
17-01-2015 9:45 PM
Thanks @11110_110 - guess that wouldn't help... although surely we'd be seeing poor performance once connected too?
Once the PPP sessions are up everything's fine. Line performance seems pretty normal for the connections and we've not noticed any significant degradation in terms of speed.
Just seems to be a major issue getting a PPP response back / establishing a session ?
Message 16 of 24
(373 Views)
19-01-2015 10:25 AM
Thanks for that info.
With regards to both lines our systems are showing that there's a degraded service in the area which is due to be resolved by the 23rd.
This will prevent us from raising that further until that's been fixed but it will be interesting to see if the issue continues afterwards.
Message 17 of 24
(373 Views)
19-01-2015 10:27 AM
Thanks Matthew - is this related to the capacity issues at the Norwich exchange by any chance?
Will keep everything crossed that PPP stays up for now
Message 18 of 24
(373 Views)
19-01-2015 10:40 AM
It will most likely be yes.
They may either add extra capacity on the kit your connected to or move you to another one.
We'll see have to see what happens. I dont think the two are linked but I have seen stranger things happen
Message 19 of 24
(373 Views)
19-01-2015 11:31 AM
Fair enough! Would it be possible for someone to let me know when the work has been completed please (or point me towards somewhere I can check?)
I'm a little loathed to intentionally drop PPP on one of the routers at the moment just in case it then takes 4 hours to reconnect 😕
Message 20 of 24
(373 Views)
19-01-2015 11:46 AM
Unfortunately there isn't anywhere you can check yourself but I've set a reminder to myself to check on Friday.
I'll drop a update on here if the work gets completed early or if anything else changes.
Message 21 of 24
(373 Views)
19-01-2015 11:47 AM
Thanks Matthew - appreciated
Message 22 of 24
(373 Views)
21-01-2015 8:04 PM
Hi Matthew, just for info more than anything, our router resynced this evening around 19:40 for some reason. Although there didn't seem to be any reason for sync dropping, on the positive PPP was reestablished without any issues or delays
Message 23 of 24
(373 Views)
22-01-2015 9:23 AM
Message 24 of 24
(373 Views)
- « Previous
- 1
- 2
- Next »
