Time in router menu is wrong
FIXED- Subscribe to RSS Feed
- Time in router menu is wrong
30-06-2016 10:03 AM
I logged into my router the otherday and the time is showing a different time to what it should be? I rebooted the router from the main menu and it is still the same time?
My router is a TGN582n is there a firmware update for this router?
Fixed! Go to the fix.
Re: Time in router menu is wrong
30-06-2016 10:17 AM - edited 30-06-2016 10:18 AM
How wrong? Just wondering if it is a DST issue or a complete lack of correct time at all. I thought that the router was synced with an NTP server out of the box, or it used to be.
30-06-2016 10:23 AM
2 hours wrong! but when i plug a different router in the time is correct?
30-06-2016 10:24 AM
If it is exactly 2 hours wrong then I would suspect time zone issues as it is highly unlikely that it has somehow completely by chance set itself to exactly 2 hours out.
30-06-2016 4:08 PM
The time configuration settings on my TG582n is as follows:
Network time synchronisation should be done from ntp.plus.net though for that to work I think the firewall setting for the account might need to be Off or Low.
30-06-2016 4:16 PM
the tick boxes were unticked? even after a reboot of the router they remained unchecked? i ticked both boxes and all seems well!
Thanks guys
