Time in router menu is wrong
andytay
 I logged into my router the otherday and the time is showing a different time to what it should be? I rebooted the router from the main menu and it is still the same time?
My router is a TGN582n is there a firmware update for this router?
5 REPLIES 5
Lurch
Re: Time in router menu is wrong
How wrong? Just wondering if it is a DST issue or a complete lack of correct time at all. I thought that the router was synced with an NTP server out of the box, or it used to be.
andytay
2 hours wrong! but when i plug a different router in the time is correct?
Lurch
If it is exactly 2 hours wrong then I would suspect time zone issues as it is highly unlikely that it has somehow completely by chance set itself to exactly 2 hours out.
spraxyt
Resting Legend
Fixes: 75
The time configuration settings on my TG582n is as follows:
Network time synchronisation should be done from ntp.plus.net though for that to work I think the firewall setting for the account might need to be Off or Low.
David
andytay
the tick boxes were unticked? even after a reboot of the router they remained unchecked? i ticked both boxes and all seems well!
Thanks guys
