Ticket 162659770 24th November Current download 1.77mb FTTC
malkpm
The fault has been diagnosed as a fault in the copper.
The last conversation with the help desk
"test has failed and has found an Impairment in copper joint detected most likely in local network.
Indeed but at least we are still seeing the issues you are seeing are down to the Openreach part of the setup, so it's not us or yourself"
So, with my download this morning as per BT Performance Test was 1.77mb.  Phone line is also noisy.
Yesterday I had dropouts streaming music.
Can anyone please help as to when this fault will be fixed?
Thanks for looking.
4 REPLIES 4
Fixes: 1,600
Re: Ticket 162659770 24th November Current download 1.77mb FTTC
Hi there. I can see we've reported the fault over to our suppliers.
We'd expect this to be investigated within the next few days.
Our faults team will contact you when we've got more info.
malkpm
Thanks Gandalf. Openreach have improved my line a little. New connections  / faceplate etc.
As you can see from files attached I am still down on previous speeds. Will this readjust in the next few days?
Anything you can do to tweak settings?
Mal
MatthewWheeler
Fixes: 479
I've tested your line and attached the results below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 6.3 Mbps
Upstream Speed 1.2 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2017-12-13T10:27:02Z 2017-12-13T10:42:02Z
Ingress Code Violation 5 0
Egress Code Violation 24 0
Errored Seconds 11 0
Severely Errored Seconds 0 0
Unavailable Seconds 0
There's a chance they may increase back to the previous levels but as the current speeds are within the estimates and due to your distance from the cabinet we can't push it any further
 Matthew Wheeler
malkpm
Thanks Matthew. I am pleased its back within specified limits and do understand about the line length.
With speeds so low every bit helps.At least I should be able to watch iplayer with better quality and no buffering.
