Throttled Download Speed
- Throttled Download Speed
05-02-2019 1:51 PM
Product: Unlimited Fibre Extra
Exchange: https://availability.samknows.com/broadband/exchange/LNHOR
Retrieving speedtest.net configuration...
Testing from Plusnet (146.199.7.68)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Interoute VDC (London) [22.76 km]: 26.797 ms
Testing download speed................................................................................
Download: 33.74 Mbit/s
Testing upload speed....................................................................................................
Upload: 13.39 Mbit/s
This host is hardwired. There is no local network issues. I can reproduce this throughout the day; peak and off-peak.
https://kitz.co.uk/adsl/btwchecker.php - Shows my last observed speed as:
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps) 37.21 Max Upstream Observed Speed (Mbps) 15.85 Observed Date 2019-01-29
Any idea what is going on here?
Holmes93
Re: Throttled Download Speed
05-02-2019 3:35 PM - edited 05-02-2019 3:35 PM
I've tested your line today and our tests aren't showing any throttling or banding on the line as shown below:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 37.2 Mbps |
Upstream Speed | 15.9 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 472.8 |
Upstream Rate Assessment | Low |
Downstream Rate Assessment | Low |
Interference Pattern | Regular Interference Observed Daily |
Service Impact | No Impact Observed |
Interference Duration Longest Occurrence | From 07:00 to 14:45 |
Interference Location | Customer Premise |
Interference Observed In Days | 9 |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2019-01-23T15:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 37.2 Mbps | 37.2 Mbps | 37.2 Mbps |
Up Stream Line Rate | 15.8 Mbps | 15.8 Mbps | 15.8 Mbps |
Up Time | 898.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-02-05T15:16:41Z | 2019-02-05T15:31:41Z |
Ingress Code Violation | 13 | 1 |
Egress Code Violation | 4 | 0 |
Errored Seconds | 2 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Your connection also seems to have been up for almost 3 months with no drops.
Can you reboot your router letting us know how your speeds look afterwards? If your speeds haven't improved then I'd recommend following the steps Here raising a fault to us Here.
