Throtted at 40mb after fault
FIXED- Subscribe to RSS Feed
- Throtted at 40mb after fault
16-04-2018 1:35 PM
Hi
my speed dropped last week or two to 42mb, after originally being 50-55ish for years
After having a fault reported BT engineer came Friday and found a fault in the cabinet, he switched ports and now i can see my port is ECI with firmware D086 (so its newer than the older B206) it was. I'm using a Cisco 887va router.The engineer said something about ringing India to have the port changed and he said he thought they had done their work.
My download speed on checkers including the wholesale one is exactly 40mbps, the wholesale checker says the speed should be upto 53 profile so the speed is not all the way across the bar to the max.
My line is now synced at 55mb. after contacting plusnet they said i'm on the unlimited fibre and i need to upgrade to unlimited extra, which i did and it has gone through today. the line speed says 80mb on plusnet's portal, but its still 40mbps download.
i reported it as something is still wrong to plusnet, but last time it took them a week to reply from the faults team. anyone got and help with what is causing the throttling.
thanks
Chris
Fixed! Go to the fix.
16-04-2018 3:51 PM
Re: Throtted at 40mb after fault
16-04-2018 6:00 PM
Sorted, thanks very much Matthew for speedy reply
